Configures the DHCP relay agent remote ID.
| remote-id | Specifies configuring the remote ID. |
| system-name | Specifies assigning the switch's system name as the remote ID. |
| remote-id_info | Specifies assigning a user-defined string as the remote ID (up to 32 characters). |
If neither a system name nor the customized remote ID is configured, the default is the switch's MAC address.
This command specifies setting the remote ID as either the switch's system name or a user-defined string. If neither selection has been made, or you unconfigure the remote ID (unconfigure ip-security dhcp-snooping information remote-id), the default remote ID is the switch's MAC address. However, this default (MAC address) name does not appear in the show ip-security dhcp-snooping information remote-id command.
The following command configures the DHCP remote ID as the switch's system name::
# configure ip-security dhcp-snooping information remote-id system-name
The following command configures the DHCP remote ID as "mydhcp":
# configure ip-security dhcp-snooping information remote-id mydhcp
